Saving money on thrust bearings for your shocks
Hi All,
The following are for the 2.25" shocks - as opposed to the 60mm shocks.
Adding a thrust bearing to the top of the shock mount will help eliminate the various clunking and other noises as you turn the wheel. The clunking is due to friction causing a skipping between the spring and the spring spring retainer.
Above are the part numbers - the bearing cost ~ $10.00 each, and the thrust washers are pretty cheap as well. For the front, you will need 2 bearings - one per side, and 2 washers per side. Just sandwich the thrust bearing with the washers on each side
Thrust bearing P/N
Assembled unit.
Cheap fix...
Ray
Thrust bearing P/N
Assembled unit.
Cheap fix...
Ray
3 years or so, easy enough to clean, everything is still in good shape - just cleaned them again. I installed them just under the top 'holder' for the spring. There is some dirt there, but not as much as you would think!
Works just fine for me!
BTW, the downside of using grease in this type of application, is that grease will attract dirt - or al least retain it. A very light grease or perhaps something like a way oil or even something like engine assembly lube works better,
Ray
Ray
