996 Converts ??
Originally posted by blustem
Scott, one more thing, you mentioned PCCB's.I looked for only for cars with them because of the weight savings(44LBS I believe).I don't know how to drive well enough to appreciate them BUT I will learn!!! Seriously, every one I've talked to or read about says get the PCCB's.
Good point. Unfortunately I didn't do enough research before I bought the GT3. I knew I wanted it and decided to act quickly(I knew this would be a great car.) My question would be if I had to replace them could I put the steel ones on it, or is this a retarded question? Let's hope for the best.
Yes you can retrofit to steel rotors in lieu of the ceramics. In fact it would be cheaper to buy a whole new GT3 brake system (steel rotors and red calipers) than one PCCB rotor. The fronts steel rotors are a direct fit, the rears smaller and require a different size caliper.
