996 GT2/GT3 Forum 1999-2005
Quickjack 5000 lift for sale at Costco, $999 delivered
Old Jun 19, 2019 | 01:34 PM
porschedog's Avatar
porschedog
Interesting...
Old Jun 23, 2019 | 08:50 PM
H2Ocooledesteem's Avatar
H2Ocooledesteem
Does anyone know of someone that has dropped a motor on a 911 with this unit?
Old Jun 24, 2019 | 11:50 PM
pfbz's Avatar
pfbz
I've read 34" clearance needed to drop a 996 Turbo engine, so no. Not to mention the hassle of doing it without being able to stand up underneath.
https://www.6speedonline.com/forums/...bolt-mods.html
Old Jun 25, 2019 | 11:14 AM
Marv's Avatar
Marv
Probably not enough clearance.
I did a 964 engine drop in my garage using jack stands. I made two custom wooden cradles with casters to support the engine and trans. The two cradles could be separated so the engine and trans could be rolled apart.
I used two jacks to lower the engine and trans. I did this alone, too.
Got both successfully to the floor and when I went to roll the pair out from under the car I found I couldn't clear the rear of the car.
The jack stands were maxed, so the solution was to go up into the attic and attach a hoist to the roof rafters, drill a large hole in the garage ceiling, and drop a cable to the rear of the car. I then lifted the tail of the car a few inches to roll out the engine/trans.
Not the most eloquent solution.
Old Jun 26, 2019 | 06:28 PM
black04's Avatar
black04
Default Elegant Engine Drop
On the contrary. That is the most elegant solution, on multiple levels. And you're quite eloquent, as well.
Old Jun 26, 2019 | 06:57 PM
powdrhound's Avatar
powdrhound
Easy to do. You simply need to raise the car up with the Quickjack and rest it on some elevated pads, stacked 2x6 boards, whatever. You then need to lower the Quickjack and put a proper spacer thick enough to give you the extra clearance, again, stacked 2x6 or 2x4 boards between the jack surface the the rubber pads. Once done, you simply raise the car again with the Quickjack to the height required to clear the dropped engine.
Old Jun 26, 2019 | 10:06 PM
Marv's Avatar
Marv
Have you seen that done?
It sounds plausible, but???
I'm just worried about stability.
There is always the MaxJax for an additional $700.
Old Jun 27, 2019 | 03:28 AM
powdrhound's Avatar
powdrhound
Sure it's plausible. You just can't go overboard with it but if you properly space it maybe 6"-10 than stability won't be compromised much. You just have to use common sense but the lift itself if very stable.
Old Jun 27, 2019 | 09:55 AM
Marv's Avatar
Marv
So, if I read the information correctly, the QuickJack lifts to a maximum of 21". But that is with the rubber blocks.
The actual lift is 17.6". I am assuming that is measured from the floor.
The tail of my rear bumper is 8.5" off the floor and to clear the engine I need 34" from the bottom of the bumper to the floor (34" - 8.5" = 25.5" actual lift).
Bottom line, about 8" of additional lift would do it.
That 34" presumes an unknown engine jack minimum height and I assume the removal of the rear bumper.
Old Jun 28, 2019 | 12:47 PM
black04's Avatar
black04
I've done something similar with a hydraulic floor jack, jack stands and blocks. The jack stands got me to about 16 inches high. So I used a similar method and I got the car about 22 inches high
The stability is as good as one's engineering skills and blocks. I was stupid and one corner of the car fell about 4 inches when I was lowering it.
Old Jun 28, 2019 | 02:06 PM
rjaudi's Avatar
rjaudi
Race ramps make tire "cradles" that will support the car in the air. Then you can buy the Quickjack SUV/Truck adapters to raise the car backup even higher.
