Gearbox question
Hello,
I had a quick question regarding the 996 GT3 transmissions compared with that of the 997 GT3. Do they both possess the same gearbox? And my question is more accurately related particularly to feel, the 997 GT3 seems to have a much crisper notchier gearbox compared with the 996 GT3 why is that, and have any 996 GT3 guys found a way to bridge that gap in feel?
This information is from: https://www.gboxweb.com/transspecs.html
For the 996:
G96/96
996 GT3 2004-05
6-speed fully-synchronized transaxle
Manufactured by Getrag
Plate-type limited-slip differential
Cable shift
Single-plate clutch
Oiling system with cooler
Gear ratios:
1st gear: 3.82
2nd gear: 2.15
3rd gear: 1.56 (steel synchro)
4th gear: 1.21 (steel synchro)
5th gear: 1.00 (steel synchro)
6th gear: 0.85
Ring and pinion: 3.44
For the 997:
G97/90
997 GT3 2007-11
Manufactured by Aisin
Cable shift
Single-plate clutch
Gear ratios:
1st gear: 3.82
2nd gear: 2.26
3rd gear: 1.64
4th gear: 1.29
5th gear: 0.94
6th gear: 0.92
G97/92
997 GT3 2010-11
Manufactured by Aisin Plate-type limited-slip differential
Cable shift
Single-plate clutch
Gear ratios:
1st gear: 3.82
2nd gear: 2.26
3rd gear: 1.64
4th gear: 1.29
5th gear: 0.94
6th gear: 0.88
2 different manufacturers...
For the 996:
G96/96
996 GT3 2004-05
Cable shift
Single-plate clutch
Gear ratios:
1st gear: 3.82
2nd gear: 2.15
6th gear: 0.85
For the 997:
G97/90
997 GT3 2007-11
Cable shift
Single-plate clutch
Gear ratios:
1st gear: 3.82
2nd gear: 2.26
3rd gear: 1.64
4th gear: 1.29
5th gear: 0.94
6th gear: 0.92
G97/92
997 GT3 2010-11
Cable shift
Single-plate clutch
Gear ratios:
1st gear: 3.82
2nd gear: 2.26
3rd gear: 1.64
4th gear: 1.29
5th gear: 0.94
6th gear: 0.88
Aloof (06-24-2019)
