I run a heat shield on speed sensor. Yours is naked . I use 986 606 136 00 on all my O sensors & speed sensors ...
I run the heat shields on the front sensors as seen below. I don't use the heat shield on the rear sensor as the sensor is tucked away into the upright and a good distance away from the rotor. I've never had any issues.
