GT2/GT3 Camber Adjustment Shims?
Thanks for that info Brian...Problem is, I just don't trust my dealer. Guess I need to find a race tuner in a 3 hour radius from home and set up an appoitment to have it checked and adjusted if necessary. I have not noticed any handling problems or uneven tire wear, but then again, I only have 1500 miles on the car...
My shop tried adding shims for a bit more negative camber but the bolts holding the shims and the two parts of the arm together are only long enough for about 8mm of shims. So they ended up twisting the mounts and removing some of the shims. With 3mm shims remaining and the top mount bolts in the centers of their chassis slots, I've got -3.0 degrees on the car. It will be easy to readjust camber more or less now when necessary.
