What brake line sizes are on the GT3 master cylinder
Yes, the PSM Boxsters use a 12/10 MC. It's the non PSM cars that have 12/12
Hi John,
I would like to see a picture. The ABS unit is just not in the budget at this point... Sounds like you have a very good setup there.
Are you running 18" rims with those rotors?
Ray
Ray
Thats correct Ray. 18x10 fronts and 18x13 rears. I will get you a picture of the pressure transducer on Sunday when I return.
Here is the brake pressure transducer set up I'm running. This is a very clean way of doing it as it avoids any flexible brake lines. This is how Porsche Motorsport did it on their race cars.
It consists of:
1x Motec 2000psi pressure transducer
1x EPDM O-ring (withstands brake fluid)
1x Male 10 x 1.0mm Metric convex seat to 3AN adapter
1x OEM brake line banjo fitting (914.355.531.00)
2x OEM copper crush washers (904.355.902.00)
1x OEM Porsche Motorsport 12mm banjo bolt (993.355.517.80) - * No longer available
The PM banjo bolt is unfortunately no longer available so I had several of these manufactured based on exact measurements I took off of the original part. Essentially it is an exact replica of the PM part machined out of stainless steel. I do have a few extras of these if you decide to go this route.
Hope this helps...
It consists of:
Hope this helps...
