DIY Oil Change Mistake?
I may have made a mistake in a recent DIY Oil Change. Removed the nut noted on the picture (left side under metal tube insert), saw the spring and realized I was in the wrong place. Replaced immediately, a little engine oil escaped, but nothing more popped out. Any damge done??? I think this is part of the crankcase assy.
Plug I removed is on the left under the metal hose attachment
I'm not sure, but it is probably the oil pressure relief spring assembly.
If you replaced everything in the order they came out........ spring and maybe a ball bearing or piston, you should be good to go.
I did the same thing on a 993 years ago...................................
pressure relief value- You should be ok I think. Someone with more knowledge will respond I'm sure,. I think there is a spring , piston , seal etc in there.
