WTB: 996 GT3 Intake cams
Putting my motor together and found this:
Pretty sure that the last guys in here tried to undo the big nuts with the setup plates still installed...
Ray
Ray
I hope he found all the broken piece(s) before they were ingested...….. That would have needed a huge leverage on the wrench to break the steel end off !!
What do the other cam end pieces look like?
Stephen:
The other ends are ok, good enough to set cam timing.
Tommy: Not directly. Having to rebuild this motor was a blessing in disguise. The previous owners and the shop they used were complete idiots. Since EVERYTHING has been apart, there are no bits anywhere, nor have I found them. From the type of break, it was probably when they were taking things apart.
I also found this:
