2nd gear detent - prevents popping out of 2nd gear
is this a potential issue with our cars?
I've not seen any discussion and my car does not exhibit any issues with popping out of 2nd gear.
http://www.gboxweb.com/detent.html
Cheers
Craig
Cheers
Craig
ive heard from my shop to not use that thing, it's garbage and will lead to more expensive repairs down the line.. .. take it for what it's worth... but like was said above, Ive never heard of that happening on GT3s. It's a tolerance/pre-load issue in the turbo gearbox, although I could be remembering wrong.
Any G96 variant gearbox with a 2nd year popout issue today is because the synchros and shifting parts are worn and need tone serviced.
2nd 911, 2nd time using the Gbox 2nd gear detent.
Not due to solve already there symptoms, but a precautionary measure.
I can't comment on if you already have the problem but at least can say that its been a peace of mind thing for me.
Neither one of my cars had the 2nd gear pop out before and after installing the Gbox detent I've tracked both of them hard without any warning signs. Seems alright to me.
why not just add the 8mm ball bearing that porsche added? seems to have fixed any issues. if the shim stack isnt proper theres going to be issues doubt theres any external fix for that
But the GT3 transmissions don't have this pop-out issue in the first place... the trans was put together properly from the factory.
