Error code
Error codes beginning with "1" are manufacturer specific and may not even be the same from model to model.
If the engine is running ok and the light isn't flashing you can use the tool to clear the error code. (If you can read the freeze frame data and write down all the info and check for any pending error codes and if any write those down too.)
Then drive the car. If the CEL comes back on and the eror code is present you probably need to have the car looked at by a Porsche dealer service department. It has the latest info on what all P1XXX error codes mean.
