Which Tires for Street
I'm in a pickle here and need to find a set of 4 tires.
Tire Rack has two choices (PS2s are too expensive right now).
Pirelli P-Zero Rossi for $880
Sumitomo HTR Z for $498
I'm leaning toward the Pirelli if they are really a better tire.
I've run both the HTRZ II and III. I can't remember which Sumitomos can be flipped on the rim for extra life, but I think it's the II. Depending on how much it rains where you are, that might not matter, and you could flip them regardless.
-td
Tire Rack website shows the new Continental Extreme Sports are available in GT3 sizes for the street (295/35 rear instead of 295/30). I have these tires on one of my cars and have had previous versions of these on other cars. They are a pretty good tire and not that pricey.
Chet
Chet
Ditto, cheap tire's for driving on the street or to the track!
I have a pretty aggressive track alignment, so I run the Sumitomos (and have for almost 10 years). They are "meh" on the street - but they have a high tread rating so they last a while.
-td
-td
Sumis more than fine. Heck, I ended up doing 6 days on track at the Glen and Calabogie with them. Nothing to love, but they work and don't chunk.
My interest was the hardest, longest lasting street tire to endure a track alignment/abuse. They pass the test!
M
M
ugh.. ordered semi's from tire rack for my newly acquired car... and costco wouldn't install them bc they don't meet the load rating in the rear.... i guess i will bite the bullet and buy the michelins..
Was Costco a Tire Rack associated installer? There is likely some other reason Costco refused. Just go elsewhere.
FYI if you are shopping for performance tires for your MecLexBMWMazAcuETC the same tire available at Costco is much cheaper at an independent tire shop, ordered from a distributor. Everyone seems to think that Costco has the best/cheapest stuff
You mean Sumitomos? That doesn't seem like it could be correct. Did you verify those numbers?
-td
The math suggests the 94Y are "ok"... but I ended up buying the michelins
