Need Help Quick regarding H&R Coilovers
I have an 03' manual C4S and am about to purchase the revised H&R coilover setup. The problem is that there is no listing for a C4S coilover---it is only offered for a C4 or a Turbo.
I originally purchased the H&R coilover set up for a Turbo since the C4S has the same suspension (correct??) but when i double checked with H&R, they told me to purchase the coilover for the C4. This didn't make sense to me and got me worried so i returned the damn thing.
Can anyone tell me which one i'm supposed to purchase?? I original thought the Turbo setup would work but the H&R tech told me differently...Can anyone clear this up?
I also purchased the H&R sway bars for the Turbo with the intention of putting it on my C4S, since they don't make one specific for a C4S. Will this work or should i just return these also?
I have 24hrs before the 20% coupon for Performance products expires so i need help ASAP! thanks
you want the ones for the C4, not the turbo. the turbo ones have a much higher spring rate F-R. the C4 ones are 180-240 lbs F/270-320 R while the turbo ones are 210-260 F/515-685 R. you should order the C4 H&R coil overs.
Re: Need Help Quick regarding H&R Coilovers
https://rennlist.com/forums/showthre...%26R+coilovers
thanks...seems like i'm gonna try my luck with the pss-9's for a C4...after reading a bit, i don't think i wanna find out how bad h&r customer service is first hand.
I've got the new 2nd generation coilovers with the tender springs UNDER the main springs....this took OUT alot of the problematic noises and bottoming out issues that I've heard of.....
I believe I'll have many more fun and enjoyable miles to come.....
good luck and happy trails
Thanks senna, Your car looks awesome with the ssr's and the coilovers...i was considering a set of ssr's also. What height is your coilovers set at? (how much lower)
i ended up picking up the Pss-9's for a C4....apparently H&R developed the springs so i figured i'd just pay extra for the peace of mind and the bilstein shocks.
Total price for the pss-9's came out to just over $2500. Did i pay too much?
My coilovers are set at 35mm frt lower, and 30mm rear, camber is -1 degree front and -1.5 rear, ...basically the GT3 setup, with STOCK toe settings
