996 Forum 1999-2005
Rough idle
Old 11-17-2003 | 10:12 AM
vjd3's Avatar
vjd3
Default Rough idle
My 99 C2 has a slightly rough idle, revs seem steady enough but the car shakes a little bit, slightly more than my 95 993 did. Is this typical for a 99 996? It also hunts a little bit when the weather is cold (30s).
TIA,
Vic
99 C2 cab
Old 11-17-2003 | 05:05 PM
parkman's Avatar
parkman
my car has the same problem once in a while. I'm going to try to change my airfilter to see if that fixes the problem. i have a 99c2 fyi.
Old 11-18-2003 | 01:30 AM
Gordon_F's Avatar
Gordon_F
My 1999 C4 has 15,000 miles on it also idles rough, and has since new
Old 11-18-2003 | 01:40 PM
Zish's Avatar
Zish
Add me to the list as well. Strangely, it seems to get better when the a/c is on
Old 11-18-2003 | 01:57 PM
vjd3's Avatar
vjd3
Probably because it idles a little higher when the AC's on. Could just be a characteristic of the car, I suppose ... every 993 I've been in had the shakes at idle, as did all the older 911s.
Vic
99 C2 cab
Old 11-18-2003 | 03:52 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Gents;
Why don't you remove the Idle Stabilizer and give that a good cleanout with carb cleaner,....
Old 11-18-2003 | 04:16 PM
vjd3's Avatar
vjd3
Where's it at on the 996, Steve?
Vic
99 C2 cab
Old 11-18-2003 | 08:56 PM
Its attached to the left side of the throttle body and I'd remove it and clean it, and the passages out very thoroughly.
Quick Reply: Rough idle
