Engine mounts and pulleys and belt
Thanks it has 67k miles, flushed the coolant. Brake fluid flush, oil/ filter, cabin air filter, cleaned radiators/ condensers, added screens to bumper .
Still need to do spark plugs, trans fluid, front diff fluid
Good work, I too just completed the above with my 60k service. Have you considered the water pump and thermostat? Did those also as preventative maintenance based on several threads I have read here on Renn.
Thanks, probably do water pump and thermostat after some other stuff probably next year , like spark plugs, trans fluid and front diff fluid, air filter
That's one clean looking engine! What year/How many miles? Garage queen? (not disparaging - just lack of a better description...).
