Rennline 4" shift riser
I've removed the center console of my car and relocated the window switches up to the dash now... that said - I have also installed the Numeric Racing shifter. I want to put it up on the Rennline 4" riser now. My understanding was that I would need to raise the e-brake handle - so I did that with the Function First 2" risers.
My question before just jumping into this is with the cables - the 4" riser angles back - which should eliminate some of the tension of the cables...
Anyone done this before and was there enough adjustability in the cables to do this?
Well, I answered my own question. It looks like the emergency brake handle is going to interfere a little bit, however there's and backward adjustment opportunity in the riser mount it self. I don't think it's going to be much of an issue, but it certainly does not appear That there will be any issue with the cable.
Easiest answer is to remove the ebrake and rear shoes. Less unsprung weight and makes it a real race car. Although there are definitely times I've gone "now why did I do that again?"
There was enough adjustability in the riser to clear the handle. Regardless - I imagine that the e-brake will go away when this thing becomes a spec car.... I love the new height.
I didn't know about the CAE before buying the Numeric. My friend has the CAE shifter installed in his track car... he likes it but I think I recall him saying that he thought the Numeric might be a better choice.
I like the look and height of the CAE as well - but I also already had the NR.... the height of the CAE is why I added the Rennline 4"
Numeric is worth every penny on the track but not on the street IMHO.
Precise and notchy. GT3 is a nice shifter as well. If price conscious, there's a Boxster guy that makes shifters that are supposed to be really good and cheap as well.
Interesting. I don't mind precise feel, but don't want something too harsh. I appreciate the info, I think the GT3 shifter will probably do the trick
I have used the stock 997, the B&M short, the Numeric short, and the OEM SSK as well as messing around with the CAE.
Stock 997: It's actually okay for what it is.
B&M: Surprisingly sloppy in my 996 for my tastes. When I upgraded the motor and trans mount it made a HUGE difference - but the shifter was still sloppy.
Numeric: I have had it in my 997 for probably 15K miles (mostly track). I used mid-throw settings on it. It was PERFECT and worth every penny on the street as well as the track. It's precise - but not too harsh. I now have it in my dedicated track car - the 996 at the shortest throw possible - its very precise and bolt-action feeling. I will try it at Sebring in a couple of weeks.
The OEM SSK: Very similar to the B&M - shorter throws but nothing like the Numeric.
CAE: Precise, hard, notchy, and intollerant - I would say it came across as a bit harsher than the Numeric set on its shortest throw.
CAE: Precise, hard, notchy, and intolerant - I would say it came across as a bit harsher than the Numeric set on its shortest throw.
Blue chip has tried my CAE shifter, he is absolutely correct about the feedback. If I would be racing I would go for a Numeric. Faster shifts.
CAE is beautiful and cool with an amazingly short throw. Hard to adjust.
