My '03 996 C2 with 997/991 style headlight covers
#61
3m tape or silicon adhesive would work. My shop used 3m double-sided tape similar to this:
https://www.walmart.com/ip/3M-Automo...-6376/39148300
two side tape can be removed easily. If you want to be extra safe, then you can put a headlight film like Xpel over your entire light before sticking on the covers (that's what I did).
Regarding the pop-up washers, these can also be deactivated by pulling a single fuse. Information is in the fuse chart that should be in cover of your fusebox or in the manual.
#64
Range Master
Pepsie Lite
Pepsie Lite
Don't those cover the turn indicators and the parking lights?
#66
They do not cover the turn signals since they are integrated into the headlight itself. They do cover over the foglights. More information and pricing information on this thread:
https://rennlist.com/forums/parts-ma...ew-design.html
#68
Range Master
Pepsie Lite
Pepsie Lite
eye of beholder............. hey, some guys are "chubby chasers".............
#69
I hadn't considered headlight covers until I saw Andrew's design. My wife purchased a set as an early Father's Day gift. I have to say that purchasing these from Andrew was a true pleasure. His communication was fantastic! Emailing with updates every step of the way keeping me informed of the progress. He sent pictures once the painting was completed and followed up with a tracking number once they were shipped. The fit and finish was excellent. I'm really happy with how they turned out. If you're on the fence I would say go for it.
I found that 100% silicone worked the best for attaching them. I tried 3M tape originally and didn't like the extra height it added. I would also recommend removing the lights for installation and sliding the cover as far forward as possible.
The covers don't obstruct the blinkers / hazards lights at all. See video.
#70
They do look to be the best option on the market. I do like the solid colored ones better (pictured) so far.
#71
#72
Not a 996 owner any more, but these look far better than some of the other 'solutions' I've seen...
how about a picture at more of a flat angle to the covers, like from the side?
#73
#74
