996 Forum 1999-2005
Repainting wheels
Old 03-19-2017, 08:33 PM
mpd425
mpd425's Avatar
Default Repainting wheels
My wheels have a few spots where the clear coat is peeling and getting new wheels is not in the budget. So I decided to repaint them. Just did the one done so far
Old 03-19-2017, 08:51 PM
jpNcos
jpNcos's Avatar
Very nice!
I need to do the same. How hard were they to take apart?
Old 03-19-2017, 09:24 PM
taylor15
taylor15's Avatar
Looks great! What paint did you use?
Old 03-19-2017, 09:37 PM
mpd425
mpd425's Avatar
Easy to take apart. I looked up the other threads about refinishing the wheels. I used Rustoleum wheel paint color is Graphite. it is a little darker than the Duplicolor/VHT. I used VHT Black, satin on the bolts.
Old 03-19-2017, 09:50 PM
mpd425
mpd425's Avatar
I also painted the center console body color a few weeks ago
Old 03-19-2017, 10:03 PM
mattie_k
mattie_k's Avatar
I've been thinking about doing the same type of thing to my rims as well. What bit and torque specs?
Old 03-19-2017, 10:21 PM
mpd425
mpd425's Avatar
8mm triplesquare (12 point) and 145 INCH lbs(12.083ftlbs)
https://rennlist.com/forums/996-foru...-refinish.html
Old 03-20-2017, 09:52 AM
dporto
dporto's Avatar
Received 1,154 Likes on 791 Posts
What sort of prep did you have to do on the center console? Did you strip the existing "soft touch" finish? What type of stripper did you use? Did you run into any problems? Any special additives for the finish paint? How did the final finish come out? Did you clear-coat it after the color coat? How much paint did you use?
I know, a lot of questions, but I'm looking to do mine as well, and I figure you can save me some headaches
Old 03-20-2017, 12:18 PM
Rick_K
Rick_K's Avatar
I used Color Bond on my center console......all the paint is matched OEM on the website....it was easy I spent 75.00
Old 03-20-2017, 02:13 PM
dporto
dporto's Avatar
Thanks Rick. What website ? "It was easy"...specifics please. I know it's "easy", I've done quite a bit of paint work. When it comes to painting, anyone who's done it knows that it's all about prep- what did u do to prep your console ? Thanks again
Old 03-20-2017, 02:24 PM
Rick_K
Rick_K's Avatar
The web site is ColorBond and they have many how to videos. I think its a great product...it looks and feels good.
http://www.colorbondpaint.com/collec...preSelect=1130
Old 03-20-2017, 02:44 PM
Rick_K
Rick_K's Avatar
The one tip I have for removing the center console would be to move the passenger seat forward and lay the back of the seat all the way down onto the rear seat. this will allow you to get the console over the top of the emergency brake handle without scratching it
Old 03-20-2017, 09:55 PM
mpd425
mpd425's Avatar
I used color match from paintscratch.com and a couple coats of clearcoat. I bought a center console that did not have the soft touch paint on it so it would be easier. The ashtray delete was soft touch I used some 80 grit to get most of it off then went to 150 then 320 to finish.
Old 03-20-2017, 10:15 PM
dporto
dporto's Avatar
Old 03-20-2017, 10:42 PM
wyovino
wyovino's Avatar
I have the same wheels as a spare set. They could use a little TLC. Do you know how close the lighter shade of Rustoleum wheel paint is to the original?
Quick Reply: Repainting wheels
