996 Forum 1999-2005
Thread lock or not on
Old Feb 9, 2017 | 03:12 PM
roadblock's Avatar
roadblock
Default Thread lock or not on
Water pump bolts -blue - and no RTE on pump gasket area ?
File Type: jpg
File Type: jpg
Old Feb 9, 2017 | 03:25 PM
Quadcammer's Avatar
Quadcammer
no rte, no threadlocker
Old Feb 9, 2017 | 03:26 PM
roadblock's Avatar
roadblock
Ok - Thx
Old Feb 9, 2017 | 07:13 PM
Schnell Gelb's Avatar
Schnell Gelb
If you are re-using cleaned, dry MEC bolts in cleaned,dry threads, Loctite 290 or 222 would be a good idea ?
The reason is that without the MEC coating & the correct fastener torque being so low, it may back out. At higher torque like there would be for steel bolt+steel casting ,no need perhaps.
http://henkeladhesivesna.com/blog/th...threadlockers/
I prefer using s/s studs+s/s nuts instead of bolts where possible for the M96 . Steel bolts in an expensive ,soft Aluminum casting is a potential problem in older cars where the original fastener has been in and out multiple times.The face of the w/p looks perfectly clean ,so that will help.YMEV. First ,do no harm....
Old Feb 9, 2017 | 07:19 PM
roadblock's Avatar
roadblock
The reason is that without the MEC coating, the correct fastener torque is so low, it may back out.
I prefer using s/s studs+s/s nuts instead of bolts where possible for the M96 . Steel bolts in an expensive ,soft Aluminum casting is a potential problem in older cars where the original fastener has been in and out multiple times.YMEV
Thanks Schnell - purchased new bolts and set the torque at 7.5 pounds - I did reuse old bolts on thermostat housing - I can back them out and put thread lock on them( went with LN thermostat for cooler temps) thx
Old Feb 9, 2017 | 07:46 PM
roadblock's Avatar
roadblock
Just ordered both 222/290 - put on new plugs and coils- new coils are thicker than original - in Raby spec book says torque on coils are 7.5 lb - worried it might break case since it's different design- your thoughts?
File Type: jpg
Old Feb 9, 2017 | 10:35 PM
Schnell Gelb
Follow the torque specs in the FSM or Jake Raby's Torque Spec book.
That is a hot location so maybe 294 is better there. You only need a little.
That situation is not trying to achieve some precise clamping force or stop fluid leaks. It is just to stop the coils backing off the spark plugs.
Careful not to muddle NM and ft-lbs !
Old Feb 9, 2017 | 11:13 PM
OKB's Avatar
OKB
I only use silicone and Thread sealant if I have a leaky water pump. I it is problematic I will silicone or glue the gasket to the pump and use pipe thread sealant on the bolts. If it never leaked around the gasket i do everything dry
Old Feb 9, 2017 | 11:28 PM
roadblock's Avatar
roadblock
The book says this is right - but it's a different thickness on the beru coil- old coils have a metal sleeve- not sure new ones have that.
Old Feb 9, 2017 | 11:29 PM
roadblock's Avatar
roadblock
