Short in Cigarette Lighter Socket?
![Angry](https://rennlist.com/forums/images/icons/icon8.gif)
The fuse to the cigarette lighter on my 2002 C2 Cab keeps blowing out. I use the socket for my cell phone's car charger. Is the culprit that there's too much current being pulled, or could there be a short? What size fuse should I use, or the max size I should use?
Look at the fuse assignment sheet on the cover for the fuses. I have an older car and the lighter is row D fuse # 5. 5 amps. Nothing else is listed on the circuit for that fuse. Jeff
4th Gear
I had the same short in my lighter. I was told at a Porsche dealer that it was a design defect, and to make the lighter not short, place the metal fingers of your lighter plug at 1:00 and 7:00 in the socket. Otherwise, the metal fingers can cause a short.
I also replaced three fuses and watched them "pop".
The fix was under warranty.
Ron
Ron
