What is this sound?
Need some help. What is this sound? Sorry, it's so faint
I only hear it from inside the cabin. It goes away when I press the clutch. I only hear it after the engine has warmed up.
Thanks in advance
Thanks in advance
About 10 times per second. My guess is something inside the clutch system, probably the throwout bearing. Someone will need to lift up the car and id the source more accurately.
Thanks, I've been having some issues with the clutch lately. It's started rattling at low revs when engaging first gear. The other day, the clutch pedal didn't pop out fully going into first. Both clutch and flywheel have ~3K miles on it. Does that shed anymore light? To my knowledge, stock parts were used.
Definitely something not right inside the bell housing. The transmission will need to be dropped again. If it was done by a shop, I suggest you take it back to them to sort it out. There ahould be warranty of the work amd parts.
FYI, the car only has 24K miles and the mechanic confirmed the gearbox oil was toast. It's something you all my want to tackle next time you have the car up on stands.
