996 Forum 1999-2005
Buying a 996 that doesn't run!
Old 01-08-2017 | 08:14 PM
Ahsai's Avatar
Ahsai
To start with the easy and obvious, you can give the throttle body and idle control valve a thorough cleaning first. Then disconnect the battery to reset the dme. Next up will be durametric reading of codes and misfires, then check the spark plugs and coils.
Old 01-12-2017 | 09:49 AM
Forrest Harnish's Avatar
Forrest Harnish
Well, i have it all cleaned up and ready to go to the mechanic shop. His diagnoses is the AOS. we put it on the durametric, still didn't say anything . I've cleaned throttle body and done plugs. Oh well, she's headed to the shop. I'm happy with the money i have in it! Also the car is a complete leather interior and LSD car. From what I've seen option 220,222,224 is fairly rare?
Old 01-12-2017 | 01:50 PM
Vdubjetta02's Avatar
Vdubjetta02
Looks very clean!
Old 01-12-2017 | 01:57 PM
Schnell Gelb's Avatar
Schnell Gelb
Forrest,
If the car has been idle for many months, the fuel may have gelled/deteriorated. It is a pain but you need to flush that out. Not just the tank and filter. You particularly need to flush out the fuel pressure regulator and fuel rail. I hope you have somewhere warm,dry,well ventilated to do such work in winter.
BTW - the gelled fuel is not very combustible. It will plug up the fuel pressure regulator. Tedious work.Can't you tell I had to do it recently ?
