Will a 3.6 muffler fit a 3.4
Hi guys
I'm looking at buying a set of einsmann exhaust for my car they are used off a 3.6 , will they fit my 3.4??
Also they have vacuum controlled throttle flaps for extra sound , would I bring a vacuum pipe off where the one that connects to the resonator flap so they open when this does
Thanks guys !!
Thanks guys !!
You can use these PSE exhausts without problem.
The actuator on each exhaust needs to be connected via an electro valve to the vacuum supply.
When you don't connect the vacuum, the exhaust will be loud all the time.
