**Please Help** Window Grinding
Hello to my 996 friends! I need your advice. Took my 996 to the mountains on Saturday and dropped the top because the temperature was perfect and scenes were too beautiful to pass up this time of year. However, when I got home, I started closing the convertible top and when the passenger window began to rise up, a sound of grinding could be heard. It almost sounded like a small amount sand rubbing up against a mechanism or something. The window wouldn't raise completely at first, but with some careful effort, I was able to get the window to close. In your opinion, is this problem associated with window motor or lifter mechanism? (see picture) Based on past threads on the subject, this seems like a text book case of the motor going bad. Your help is greatly appreciated.
https://cimg8.ibsrv.net/gimg/rennlis...220576135.jpeg https://cimg0.ibsrv.net/gimg/rennlis...5aed37ed6.jpeg |
window regulator. I replaced mine twice due to the same noise you described. about a 1 hour job.
Originally Posted by AWDGuy
(Post 13664613)
Do you know of a good video link for removing the door panel? Thanks man! |
Originally Posted by b3freak
(Post 13664493)
(Post 13664714)
Best that you NOT wait till it totally craps out (specially while in the down position). Good DIY on PELICAN: http://www.pelicanparts.com/techarti..._and_Motor.htm Try this vid (many more on youtube) |
I beleive theres quite a few videos out there. iirc, the one I referenced was for a porsche boxster and was well done. |
maybe post a video of the sound. maybe it's not the same noise and the window regulator is very expensive part so I'd hate for you to buy it based on my input alone as others say it's the motor.
(Post 13664724)
I've read some recent threads where the window motor's safety clutch mechanism is made is self destruct under a certain amount of load and it's not uncommon for this section of the motor to go bad thus causing a grinding type noise. Basically, they say what you hear is plastic parts grinding inside the motor. But at $400, I want to make absolutely sure it's not the window lifting mechanism. |
Um, why don't you just remove the door cover, roll the window and try to pinpoint if the noise is from the motor. It should be pretty obvious. (Note airbag light will trip though if your power the window with the airbag disconnected but that could be reset by Durametric).
3 Attachment(s)
here's my regulator that was making the noises you describe.
Attachment 1197692 Attachment 1197693 Attachment 1197694 |
Originally Posted by Ahsai
(Post 13664752)
Also, looking on ebay, I see cheap window regulators as low as $56 with free shipping. Used window motors are as cheap as $80 and reman ones as cheap as $175. So, either way, this should be a sub-$200 fix for you. Agree that you should just take the door panel off and take a look. Although I've never replaced a window regulator on a 996, I've done it on at least 5 other cars. They are all basically the same setup. I don't think I've ever replaced the motor on one - it's always the regulator. Based on that and there seems to be about 5 regulator ads for every motor ad on ebay, my money is on the regulator. So, since the regulator is cheap and is normally the culprit, then order one of those if you are in a situation where you can't pull the door off to look. Even if it turns out to be the motor, the regulator is probably going to crap out on you at some point in the not-too-distant future anyway. |
Thank you all. I appreciate it!
Both of my windows are making the sounds you describe... :( But my windows roll up and down with no real issues. That said the passenger door window "tries" to drop when the door is opened, but it does not drop enough to clear the roof upon closing the door as it should. I have also noticed that the tint in the upper rear quadrant are of my front windows is getting new damage from rolling up and down since the crunchiness started...
The noise and the window tint damage were not present during my PPI, so I'm thinking the increased use since purchase has caused this particular weakness to come to light. I've simply not taken the time to dig in and investigate further. Part of me wants to have the parts here to fix it before I dig in, just so I don't have to do the disassembly/reassembly twice or leave the door guts exposed while I wait. Problem is, I don't know if I need the full regulator or just a small part? When I was looking around, I saw this EPS product, which seems a bit opportunistically priced... However if you look closely at the photo with the finger pointing to that section of the regulator, it makes me wonder if that broken piece of plastic could be the cause of your noise and mine...? http://www.ebay.com/itm/Porsche-911-...ZW3zMs&vxp=mtr At $60 each, I'm probably just going to by new aftermarket regulators for each side and swap them out. I was shopping for this stuff before reading your thread. |
Originally Posted by Schnell Gelb
(Post 13664877)
This may help
https://rennlist.com/forums/996-foru...ir-sleeve.html http://www.renntech.org/forums/topic.../?_fromLogin=1 |
Same thing happened to mine recently and it was the lifter (there was a wire that was ripped up) not the motor.
