996 Forum 1999-2005
Porsche Fuchs Design wheels 19" on C4S LOOK!!!
Old 09-26-2016, 06:17 PM
Wheel Dynamics
Former Vendor
Wheel Dynamics's Avatar
Default Porsche Fuchs Design wheels 19" on C4S LOOK!!!
Look at this nice C4S that rolled in last week.... and rolled out looking fly!!!
Vehicle: 996 C4S
Wheels: Wheel Dynamics OS Design II 19x8.5 qand 19x11
Cost: $1899/set.
Old 09-26-2016, 06:36 PM
kmagnuss
kmagnuss's Avatar
What size tires are on it?
What are the offsets of the wheels?
Thanks.
Old 09-26-2016, 06:40 PM
jleblanc
jleblanc's Avatar
Wow, I love the look of these, but they're so heavy Lobsters are so much lighter for the same size. And the real Fuchs ones are $$$
Old 09-26-2016, 06:44 PM
Wheel Dynamics
Former Vendor
ONE MORE SHOT....
Wheel Dynamics
Former Vendor
Thanks.
Running 245/35/19 and 295/30/19
Old 09-26-2016, 06:46 PM
Wheel Dynamics
Former Vendor
Not true.. 19x8.5 (et-48) 24.7-lbs & 19x10 (et-47) 26.4-lbs OR 19x11 (et-52) 27.1-lbs.
Just because Lobsters are lighter doesn't make this a bad wheel, look at the 18" 993 Twist wheels, those are 18" and are 24-lbs front and 30-lbs rear!!!!
Old 09-26-2016, 07:35 PM
jleblanc
jleblanc's Avatar
I stand corrected. I thought the lobsters were 20#/23# or so, but they're 22lb 4oz and 27# 12oz, so the fronts are a little lighter than yours, but the rears are about the same.
Do you have customers putting small spacers on the rears? Seems like with the et-52 offset you might want to.
Old 09-26-2016, 08:18 PM
Wheel Dynamics
Former Vendor
Actually on the standard 996 we offer both the 10" option and the 11" option, the 52-offset will position the wheel further out towards the fenders. To play is safe you can use the 10" wide rears, however if you want to get the most play under there using the 11" I would roll fenders on the pre-3.4-L motors, however if you have the 3.6-L then your fenders are already good to go...
The C4S that is photographed is using a 13mm rear spacer since it uses a wider stance, with the spacer kit on the rear it now positions the rear to et. +39
Tire options will depend on a few things, but if you have questions when ordering feel free to ask for all size options.
Thanks for chiming in..... Let me know if you have other questions!!!
Old 09-26-2016, 08:26 PM
jleblanc
jleblanc's Avatar
OK thanks. I have an '03 C4S. I thought maybe the 14mm spacer would be the right fit, that makes sense. I figured you were doing the 11" with a non-standard offset so you could put it under the C2 fenders as well as the C4S. I was shopping around for lobsters, but when the difference is only $600 I should really consider these too, and put my pristine stock ones in the garage.
Old 09-26-2016, 08:37 PM
Wheel Dynamics
Former Vendor
You can also use the 14mm, I would say 12-14mm is safe. 38-40mm range.
These would definitely be a turn in the right direction for sure, the lobsters would also need spacing up front if you went that route since they are a et 57 so a minimum of 7mm in the front to bring it up to stock fitment.
We also stock this nice nifty color...
Old 09-26-2016, 09:13 PM
Atrox
Atrox's Avatar
I agree, I just need spacers.
Old 09-26-2016, 10:05 PM
jleblanc
jleblanc's Avatar
Which ones are those? The rears look much deeper than the version that Wheel Dynamics sells,
Old 09-26-2016, 10:17 PM
Atrox
Atrox's Avatar
avante gard ruger classics I believe
Old 09-27-2016, 12:14 AM
jleblanc
jleblanc's Avatar
Thanks! I definitely prefer the more classic shallow look. The Wheel Dynamics ones are the closest to a classic style that I've seen.
Old 09-27-2016, 01:06 AM
texcwa
texcwa's Avatar
Will you be making them in 18"
Quick Reply: Porsche Fuchs Design wheels 19" on C4S LOOK!!!
