Anti-roll bars / stabilisers versus springs – effect on ride comfort
Wow. Pardon the lack of proof reading on the last post. Rake will help even more than Take. Lol.
Ohlins have a great reputation. Getting you PSS9's tested and rebuilt as required will help some. Going with a two way adjustable with a higher spring rate will help some. But going up in spring rate will decrease your daily comfort.
I just spent 3 days on the track on an M030 (US) suspension with 30k miles and 245F/275R NT01s. And I drove the crap out of this thing like I never had before. In the passenger seat, it felt floaty, but when driving, it was extremely forgiving and crazy fast. I was 3s quicker than with KW v3s and 245F/315R NT01s. The biggest difference was learning to heel/toe and trail brake. I was in the advanced group and was passing 500, 620 and 700hp Mustangs and Camaros. I'll update my silver thread with more details.
Stiffer front springs might help with float. But as I mentioned above, so might softer front springs, or at least springs that are softer in front relative to the back.
Probably, but perhaps not definitely. The C4S bumper & spoiler eliminates roughly half the lift of the normal version. I believe the Turbo version eliminates pretty much all of it. So on it's own, if the C4S bumper gives you an improvement, the Turbo bumper might double it. Alas, I believe the aerokit II rear wing will eliminate all rear lift and might even create downforce. Either way, the combination will raise the front a bit relative to the rear which will increase lift at the front. As the only difference between the C4S and Turbo front ends is that the Turbo's spoiler extends the full width of the car, perhaps there is an add on spoiler you can use with the C4S front end?
