996 Forum 1999-2005
Replacement Cat
Old Sep 19, 2016 | 02:47 PM
L8 APXR's Avatar
L8 APXR
Default Replacement Cat
My right side cat has developed a rattle so needs to be replaced.
2 questions:
Can anyone confirm the correct part number :996-113-032-??
Is buying used an option (low risk)?
New and rebuilt units must be constructed of unobtanium given the pricing.
I want to keep the car stock so looking for an OEM replacement.
TIA
Old Sep 19, 2016 | 03:00 PM
5CHN3LL's Avatar
5CHN3LL
What year? For a '99, the right cat is 996-113-022-56 and the left cat is 996-113-021-56...
Pelican sells new aftermarket units for about $550, but they are not CARB approved (can't use in California and New York, which probably doesn't matter for a Texan, but worth mentioning just the same).
Used can be a viable option, but 996 cats are not very robust. If you go used, make sure they have a return/replacement policy if the new cat arrives DOA.
A third option (besides new and used) is rebuilding your stock cats; they cut open your existing cat and replace the catalyst. I believe some other 996 folks have done this and may be able to chime in with cost.
Old Sep 19, 2016 | 03:04 PM
Ahsai's Avatar
Ahsai
99611303206 per autoatlanta here http://www.autoatlanta.com/porsche-p...section=202-01
It may be worthwhile to check if the element just got dislodged (very common mode of failure) or it has truly "melted" and needs to be replaced. If the former you can ask a muffler shop to open it up and re-weld the insert. To inspect, just remove the cat and the post-cat sensor and peek through the O2 sensor hole and the open pipe end where it connects to the header.
Old Sep 19, 2016 | 03:06 PM
L8 APXR's Avatar
L8 APXR
Thanks for the quick replies.
Car is a 2004 AE.
Old Sep 19, 2016 | 03:42 PM
kromdom's Avatar
kromdom
Magnaflow sells CARB-legal cats for under $500 with a decent warranty
Old Sep 22, 2016 | 12:37 AM
ALE's Avatar
ALE
Call Nello @ Maxspeed Motorsports and get the 200 cel cats.
Old Oct 3, 2016 | 01:46 PM
studio112's Avatar
studio112
If you only change one cat, stay with the same as you are replacing. If you want to go after market, I would do both, not just one, and stay away from "DEC" cats; I bought those then threw them away because they kept throwing bad O2 sensor codes. I put on a used Porsche (matching) cat a year ago and it has been fine.
Old Oct 3, 2016 | 02:24 PM
OKB's Avatar
OKB
check with oaklahoma foreign for used parts
Old Oct 4, 2016 | 11:47 PM
rattlsnak's Avatar
rattlsnak
Again...
>>I did some research on a mfg number I found on some cats offered by various companies and found the company that makes them.
go here: http://www.discountconverter.com/
I know the name sounds shady, but I've used them on three different P- cars now and they are great.
Roughly $340.00 per side shipped.
Old Oct 19, 2016 | 11:23 AM
L8 APXR's Avatar
L8 APXR
Question on part numbers and compatibility. The part number of the defective cat is 996-113-032-06. While looking around for used or replacements I am seeing different part numbers - 996-113-032-02 or 03 (likely from an earlier 996 C2). Are these parts compatible?
TIA
Old Oct 19, 2016 | 01:45 PM
Schnell Gelb's Avatar
Schnell Gelb
Since you are in Tx , why not call Woody for used ones?
Old Oct 19, 2016 | 02:31 PM
L8 APXR's Avatar
L8 APXR
Woody?
Old Oct 19, 2016 | 04:40 PM
Woodman71's Avatar
Woodman71
Don't look at me.
