Unsolvable Clutch Problem?
What is strange is that if it were a mechanical thing inside the clutch the fingers on the P.Plate or throwout bearing. Why is only acting up after 100-150 miles.
In fact from my older thread, I have taken the car from my house (Seal Beach) to Palm Springs with only a few shifts to get onto the freeway, and as I approach Palm Springs (130 miles away) the clutch pedal travel is severely low causing hard to get into any gear.
This could be a issue with either your throw out bearing or a warping of your flywheel, or simply a flywheel that was not balanced correctly. The vibration is causing your fluid to get air into it which you are then pushing into the system every time you push down on the clutch.
I would start with replacing the TO bearing, first, and if the issue is not resolved, perhaps consider a different flywheel, or have the one you got resurfaced, and balanced.
I hope that this is helpful.
Erik Johnson
(720) 899-6005 phone
Erik Johnson
If this is the case, your mastercylinder isnt releasing the pressure/fluid to reservoir.
Or the pipe from reservoir to master has something blocking it.
There is only one but, if these parts really are faulty, you would notice the problem after few pedal push.
I still believe that the fault is inside the bellhousing. And that the vibration is the
key.
Your slave cylinder is acting like a miniature ulrasonic washer...
I am familiar with Sachs products but am very wary of pressure plates and discs the are referred to as Stage 2 if the pressure plate releases unevenly or is simply out of balance and or week from "tweeking" the release point which is a aftermarket trick often not working.
regards
regards
Ok, so if you dont push the clutch pedal and open the bleed screw, you can hear the slave piston move to inner position?
key.
key.
But with all your recommendations it sounds more and more that the root cause is inside the clutch assy.
I not so sure it is a problem in the clutch hydraulic system.
regards
regards
