OEM hose clamp rubbing against coolant hard line (photos)
I was reading another thread on here a while ago where a MY99 owner (or 98?) had clearance issues with coolant lines he replaced and it turned out Porsche changed some of the hardlines and hoses. You will run into clearance issues if you had mix-matched some of the revised lines with the old design lines. Slim chance but I thought it would be worth mentioning.
Yeah, I saw that the hole was caused by the poorly oriented clamp, but I wasn't able to see if there was still contact between the band and the coolant pipe. In your "after" photo, the flash shadow made it difficult (at least for me) to see if there was a gap or not.
Keep us posted on how long the repair holds - hopefully forever...
Any how they are apart.
Here is a picture from another angle, yo can actually see both tab. This is also after I twisted the clamp so the one tab isn't hitting the metal hose.
Photo rotated for some reason, the top is where the expansion tank is.
Forgot to mention, drove 30 some miles with burp vale open after topping off about a 1/2 inch of coolant. Level remained topped off and the patch is holding fine. Given it was just a pin ***** size hole, I'm callin' this DONE.
Will update if fails.
Thanks guys.
Thanks guys.
