Cassette
If you are referring to the pop out cassette bins under the climate control/above the shifter, you can get open bins/cubbies to replace that for about $30 or so. Check out pelican parts or suncoast parts, etc. Sometimes they show up on ebay too.
Keep in mind that you can actually fit 2 cubbies in the console; there are different PN's for the upper and lower cubbies in that area. The difference is in the shape of the corners on the front trim.
Hope this helps
Hope this helps
WOW...Looks like prices went up!
http://www.suncoastparts.com/product/shelf986.html
Id also check out ECS tuning, etc. Suncoast is a good site to see what things are available, and they are usually pretty good on most prices
To remove the cassette bin, open all 4 cassette slots, then with them sticking out, grab them with both hands all 4 at once and gently pull and wiggly pulling outward and the entire bin will slide out.
Not so great if you want the leather wrapped version ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Upper: https://www.ecstuning.com/Search/Sit...A11/ES1491760/
Lower: https://www.ecstuning.com/Search/Sit...A11/ES1491429/
Oh that is too cool. Just ordered one from ECS to replace my CD holder.
