996 Forum 1999-2005
Deposit paid on my first Porsche.
Old 05-26-2016 | 12:49 AM
  #46
Montychristo128's Avatar
Montychristo128
Originally Posted by lomax
Whats wrong with the headlights? They don't look that yellow and could probably be cleaned very easily. I may be missing the obvious?
Marc
The lenses are burnt on the inside from running DRL's in a couple of locations. The passenger side has burnt right through at one point so I suspect it will fail safety. Drivers is not so bad.
Not yellowed out on the plastic lens in front. I will take pictures when I get the car.
Old 05-26-2016 | 01:33 AM
  #47
Slakker's Avatar
Slakker
Originally Posted by alpine003
Aren't you the one that setup the real time RSS feed into the RL classifieds here to your phone?
Yes and your not going to believe what I bought off there today. Ok, you probably will. Need to finish the transaction tomorrow before I share details but I'll give you two hints. It wasn't from the "parts" section and I get to stay in this forum.
Old 05-26-2016 | 05:17 PM
  #48
alpine003's Avatar
alpine003
If it wasn't from the parts section and you get to stay in this forum, was it from the car classified's section? Another 996 for backup?
Old 05-26-2016 | 06:19 PM
  #49
Eviltangents's Avatar
Eviltangents
Dipping his toes in the Turbo pool maybe?
Old 05-27-2016 | 11:52 PM
  #50
Montychristo128
Oh well, its paid for and has (mostly) working lights, just one slightly pathetic front fog light, I'll clean the connections when the car arrives home.
Peter SA9 the colour code is L22E Forest Green, so not quite twins, but I do have a rear wash wipe just like yours.
Old 05-28-2016 | 01:53 AM
  #51
Slakker's Avatar
Slakker
https://rennlist.com/forums/vehicle-...ce-de-car.html
In case you didn't catch my post in the other thread. It was a done deal, and then it wasn't. It would have been a blast though.
Old 06-01-2016 | 09:47 PM
  #52
Montychristo128
Default Its hooooooooooooooooommmmmmeeeeeeeee
Car arrived last night, has temporary plates and just been for emission testing (more on that later). Here are a few questions:
1) Electrics seem to be intermittent? Wipers and front headlights sometimes they come on other times not. They work again if you switch ignition on and off. Is this normal?
2) Starter, this is really lazy, couple of turns and it starts up,is this normal or is more money needed? Maybe permanently engaged?
3) I think it needs engine mounts!!
4) Needs headlights for safety. Argghhhh.
Anyhow I took car to a local Mr Lube for Emission testing and it was great to make their night, but they did look for the engine in the front.
Old 06-01-2016 | 09:55 PM
  #53
Montychristo128
Default Pictures
A few pictures. There are a few dings and a couple of scratches, but I'm happy.
Old 06-01-2016 | 09:59 PM
  #54
5CHN3LL's Avatar
5CHN3LL
Sounds like you need a new ignition switch to address the electrical issue. Documented ad nauseam here and elsewhere. CHeap fix.
The paint looks to be in much better shape than the first picture indicated. Nice!
The starter is another common weak point. If you find that it is harder to start when hot, that's a second indication that your starter needs replacing. You can find them for about a hundred bucks on Amazon if you aren't keen to spend $800 at the Porsche parts counter. I find that my car is turning over about twice as fast with the new starter - I hadn't realized just how poorly the original was functioning.
The DRL issue sucks - you must purchase new lights to be legal in Canada because your original lights were ruined by a mandatory safety feature for Canadian cars. That seems f----d.
One hint if you plan to do your own work - buy a larger oil drain pan. I never needed a pan that could hold approx. 9 quarts before I bought my first Porsche...
Old 06-01-2016 | 10:00 PM
  #55
Carsly's Avatar
Carsly
I'd try a new battery first. These cars devour batteries like none other. The battery is the cheapest fix and often the root cause of many electrical gremlins which multiply when the charge is low. Can get your alternator tested as well to be sure.
Old 06-01-2016 | 10:05 PM
  #56
5CHN3LL's Avatar
5CHN3LL
The battery won't be the cause of the accessories working or not after fussing with the ignition. I'm willing to put up an entire dollar (US!) that it's the ignition switch.
Old 06-01-2016 | 10:39 PM
  #57
Montychristo128
Garage fitted a new one already. Paint is pretty good, blackberry camera's on the other hand total ****e.
Yes sucks regarding the DRL but I knew that one going in to the purchase.
Its starting fine just verrrryyyyyyy sllllooooooowwwwwwwwwwwwww (etc). Alternator is showing 14V on cluster. So ignition switch..... engine mounts......New vent......new (to me) lights.......... Ahhh yess and there is a relay that keeps buzzing wonder what thats supposed to work.
Old 06-01-2016 | 10:43 PM
  #58
Montychristo128
Oh yeah oil, time to reminisce, there was a 911 that somehow damaged itself when I was at the Nurburgring, they shut the road down because he left a 10km long slick.......... Ohh how we cursed. Went for a weekend and only managed 5 laps in my car due to crashes, barrier damage and this guy.
Old 06-01-2016 | 10:59 PM
  #59
Triple Black's Avatar
Triple Black
Wait - you were at the Nurburgring? In this car? I think I missed something.
As for the slow cranking - could be the starter wiring harness.
Old 06-01-2016 | 11:32 PM
  #60
Montychristo128
Nope in the Green Sierra Cosworth some posts back. Sorry I was reminded by the large oil capacity that it happened while I was there.
Quick Reply: Deposit paid on my first Porsche.
