There is mis-information abound regarding the transmission mount styles used on the different models. Here is a breakdown for the 2 styles of transmission bushings:
The singular transmission mount bushing that's pressed into the trans bell housing is used on:
996.1 Carrera (manual)
996.1 Carrera (tiptronic)
996.2 Carrera (manual)
The transmission mount carrier that uses 2 bushings and can be entirely removed from the car is used on:
996.2 Carrera (tiptronic)
996 Turbo
996 GT2
996 GT3
Thank you for your input.
I will be purchasing a set of your mounts, probably the middle choice for use in DD/DE/AX.
BTW, it took a few hours of Google searches to come up with the same information you have there in application list. Should have done more investigation before ordering.
