Durametric cam deviation on ROW engines.
I believe my engine is ROW, though it has been changed before I bought the car, so I'm not sure.
Would Durametric report a value for the bank 2 sensor even if there is none? I'm getting -9 on bank 1 and -6 on bank 2. I'm asking because I am curious about how the software works. I'm going to change the pads straight away.
This is a 2.5L Boxster engine, but I believe it behaves the same as the early 3.4L software-wise.
You can check if the bank 2 sensor is there. This thread shows some info on an engine that's without the bank 2 sensor. Was the cam deviation read after the engine was fully warmed up? My understanding is if it reads non-zero, there got to be a sensor.
http://www.renntech.org/forums/topic...nk2-no-sensor/
According to that thread the value is zero if there is no sensor. Can this be confirmed?
If ROW shows zero I must have a US engine even though I live in Europe and the car is European. Strange.
