Flat tire on highway- what to replace it with?
Received 1,902 Likes
To learn more about the importance of "grip", you must watch the first half of this video, then go purchase the correct tire.
No, I think you misunderstood me, the Michelins are what the dealer recommended when I replaced the tires about 18 months ago. The Michelins are on the car at present. I just wanted some advice on whether I should go with the same tires, or more affordable options if they last about mileage. The dealer asked me what tires I want to put on the car, and I said that I'll get back with him. He will order and install whatever is appropriate for the car. Not too many choices though.
Unless the dealer will match online pricing, you are just throwing $$ away
USMarine
HOWEVER like a previous poster said, it doesnt look like they are offered with 295 width
Are you running 19" rims, or did you play with the tire size? Just curious
Ah, gotcha.
I think you are going to have to decide if you're willing to sacrifice ultimate grip for some flexibility. What I mean by that is you mentioned you don't drive it in the snow but that doesn't mean you don't drive in cold weather.
Some of these max performance summer tires do very poorly in the cold and can be dangerous below certain temps like 40 degrees for example.
You should also specify if you're willing to sacrifice overall grip for better wet weather/rain performance.
I think you'll be able to get more accurate tire recommendations for your priority/environment/driving style if you are more specific about your needs.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
USMarine
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
This. I was also going to suggest Potenzas (RE-11's and RE-71R's) because I have had great experience with them, and actually prefer them to the preferred-by-many Michelin PSS's. However, both the Potenzas I listed take a long time to warm up, and are basically useless when cold. Speaking from experience here ![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
For cold weather duty and snow, I just don't understand why anyone would use anything other than a set of tires made specifically for winter conditions like a set of Bridgestone Blizzaks. I simply would not depend on any ultra-high performance tire, by any manufacturer, to do winter work as if it would in warmer months... it simply does not make any sense to me.
From what I've read and experienced, the rear tires on these cars seem to wear at nearly twice the rate of the front tires. Since you noted that the nail was located in one of your rear tires, I would consider just replacing the rear tires with new Michelins (to match the front tires). Do you really need to replace the front tires?
FWIW, when I brought my car in to the dealer for routine service in December my advisor noted that my C4S' rear tires needed replacement. Even they offered to replace only the two rears (without also doing the fronts).
That said, if your front tires truly need to be replaced then I would seriously consider a set of the Sumitomos. Do some research on them. In my opinion, they're a great tire (regardless of cost). It just so happens they cost a fraction of the price of the Michelins. I wouldn't dismiss them as simply "great for the price." Besides, the initial investment is so small (relatively) that even if you did end up disliking them, you could just pull them off, sell them on eBay and buy a set of Michelins for a relatively minimal loss.
Just don't mix and match tire brands/models. Good luck with whatever you choose!
-Eric
-Eric
USMarine
Nanking Sport NS-20, 225 and 265 x 18 on MY02 5 spoke....$374 for the set (delivered) from Discount Tire. Haven't been able to slide them yet....but I don't drive like that anymore
.... and I don't use the car in the rain or snow.
