996 Forum 1999-2005
sneaky carpet stalls car
Old 10-06-2003 | 03:44 AM
996blue's Avatar
996blue
Default sneaky carpet stalls car
Alright,
this is so wacky that I had to post. I had sent a note out a while back wondering if anyone else had intermittent starting problems. Everything seems fine except the car would not start off and on.
bottom line: the carpet got lose and gradually slipped under the clutch pedal not allowing full clutch travel. As a result, depressing the clutch at startup did not deactivate the safe start switch.....
would have never figured it out except the rep at Rector Porsche clued me in....obviously a common problem with manual transmissions after a while. Only takes a minor movement of the carpet.
-relieved-
Old 10-06-2003 | 12:24 PM
01 C4 Cab NYC's Avatar
01 C4 Cab NYC
..blue,
My driver side carpet used to move around a bit, and it really ticked me off, tho never prevented me from starting her up. If you turn the floor mat over does it have 2 circles that look like the soft side of velcro?
If so, there are these black plastic pieces that screw into the floor boards that have the other side of the velcro, so your mat won't shift. Turns out I had 2 on the passenger side and none on the driver side, so I unscrewed one from the passengers side and now they both stay put...
Old 10-06-2003 | 08:45 PM
996blue's Avatar
996blue
the attachments came out of the carpet.....too much heel and toe or slamming the accelerator pedal.
Quick Reply: sneaky carpet stalls car
