Head interchange
Are 1st gen 986 heads a direct interchange with the 996 heads? (I know that there is a difference in the combustion chamber size...at least I think I know that.) I have a chance to pickup a pair for a good price for spares. The part number on one of the one's I'm looking at is 99610467110R. I seem to remember hearing that some of the bolt holes aren't in the same place.
You will have to drill & tap holes to bolt on the intake manifold & exhaust heat shields. The valves will be smaller & the cumbuston chambers will be smaller raising the compression enough to require 100 octane fuel.
Thank you! That tells me what I need to know. I think I'll pass on these. The valve size and combustion chamber size are easy remedies to solve, but by the time I have all the machine work done, I'd be better off paying more for the correct heads.
