996 Forum 1999-2005
Alignment Cam Wrong Position?
Old Feb 10, 2016 | 04:56 PM
CarlOrton's Avatar
CarlOrton
Default Alignment Cam Wrong Position?
Hi, All;
Finally had a nice enough day to crawl under the aft-end of my still new-to-me 2001 C2.
I noticed something that caught my eye as probably being not where it is supposed to be. Please see enclosed pic.
The picture is taken from the rear bumper of the car, looking forward at the rear lower suspension. Left side. One of the adjustment cam bolts appears to ignorant me to be 'way out of where it *should* be. The lower part of the suspension crossmember has a lip on it like the cam on the bolt is supposed to remain in that position. Instead, it's like it's shifted upwards by about 3/16".
Is this allowable? As in, perhaps the top portion *isn't* cut into the crossmember, and this is just an out-of-the-ordinary adjustment requirement? A bit concerned because the exposed area is shiny metal. Didn't get under there to put a wrench on it because I only had it on a jack and well, you know.
Your opinions?
Carl
File Type: jpg
Old Feb 10, 2016 | 05:16 PM
Ahsai's Avatar
Ahsai
Totally normal.
Old Feb 10, 2016 | 07:21 PM
5CHN3LL's Avatar
5CHN3LL
Those eccentric bolts are a mind screw - but that looks like it's supposed to.
If you're interested, here's a YouTube video showing how a cam bolt changes suspension geometry...
Old Feb 10, 2016 | 08:31 PM
CarlOrton's Avatar
CarlOrton
Thanks; I fully understand how a cam bolt changes the geometry; my concern was that it looked like the cam/washer was not in its "seat" in the crossmember. I understand the bolt will change as the alignment is changed to pull the arm in or out.
I would have just thought it was a function of movement had the crossmember "seat" for the washer not had a lip on it like a recess that I ignorantly thought was supposed to "hold" the washer.
Old Feb 10, 2016 | 08:55 PM
5CHN3LL's Avatar
5CHN3LL
It looks funny to me every time I get under that end of the car...you're not the only one.
