996 Forum 1999-2005
RPMs vs longevity
Old Feb 3, 2016 | 08:25 PM
  #31
knfeparty's Avatar
knfeparty
I'd rather lose power than never use it.
If I wear it out after 200k miles or more, I'll buy a rebuild or another car.
Old Feb 3, 2016 | 08:40 PM
  #32
sweet victory's Avatar
sweet victory
Originally Posted by Quadcammer
Do you honestly think that that your car is building up so much carbon due to daily driving that it is having a noticeable impact on how the car runs?
Look up the carbon issues with Audi's DFI engines. I still want a B7 RS4 though..
Old Feb 3, 2016 | 08:47 PM
  #33
5CHN3LL's Avatar
5CHN3LL
^ IS that a V12 Maybach? You know, there's an additive you can get for that.
Old Feb 3, 2016 | 09:08 PM
  #34
dgi 07's Avatar
dgi 07
Hahaha.....no but the concept is there. Consistently see more trouble with garage queens than the hard drivers. Different engine design though.
Old Feb 3, 2016 | 09:32 PM
  #35
dporto's Avatar
dporto
Originally Posted by sweet victory
I'm just trying to fit in
"Can't we all just get along?"
Old Feb 3, 2016 | 09:33 PM
  #36
Triple Black's Avatar
Triple Black
I tend to agree with the OP's theory. The problem is, when I get in the car I can't seem to control my right foot and I end up in the "drive it like you stole it" camp. I think I need professional help.
Old Feb 3, 2016 | 09:45 PM
  #37
Gonzo911's Avatar
Gonzo911
Rat Balls
No, it doesn't.
Back when carburetors were popular, cars didn't run as well when cold, at low rpms, and small throttle openings. Hence the italian tune up would work reasonably well.
Its placebo on a modern car.
Yes it does Oliver. The ECU gets used to a certain pattern of driving. An Italian Tuneup makes the ECU adjust. It's not about the carbon...it's about the silicon.
Old Feb 3, 2016 | 10:16 PM
  #38
JayG's Avatar
JayG
Hell just do what one of the members does and not drive it at all and it will last forever
Old Feb 3, 2016 | 10:42 PM
  #39
golfnutintib's Avatar
golfnutintib
Race engines are completely different. They are not only driven differently, but are designed differently. In an effort to shed weight, individual components aren't designed with an endurance limit. Race engines are arguably disposable, so parts are designed for x amount of cyclic loads. To compare an engine designed for x years to x races is completely useless.
A particular driving style may shorten your maintenance intervals, but that doesn't necessarily kill your engine. Neglect kills more engines than one's driving style ever has.
Word...
Old Feb 4, 2016 | 02:42 PM
  #40
5CHN3LL's Avatar
5CHN3LL
One of my employees is a boy racer who loves to speed-shift his "'Teg" - which is boy-racer-speak for his beater Integra.
Twice now he has tried to slam the car from 4th to 3rd and hit first gear instead - and in both cases, new engines were required. Curiously, his enormous red shift light doesn't seem to help when he over-revs the car by several thousand RPM.
So, if your "style" includes being an absolute idiot, it MIGHT kill more engines than merely being neglectful.
Old Feb 4, 2016 | 06:34 PM
  #41
sweet victory
Stupid is as stupid does...
Old Feb 4, 2016 | 07:56 PM
  #42
johnireland's Avatar
johnireland
Trust you butt and your right foot. The sweet spot is when the throttle is most efficient and responsive. The engine is happy and you are happy. When you feel it you know it. And you will know when that is not where you want to be, such as stop and go traffic or a long 500 mile stretch of road without a turn in sight.
The Variocam Plus is very oil dependent, and low oil pressure and supply (level) can combine to cause expensive unpleasantness. Unless you are drag racing there is no logical reason to mash your foot to the floor from a standing start in first gear and winding it out to seven grand.
That said I did own an Alfa Romeo Giulietta Spider Veloce and stock from the factory the 1290 cc engine went to 8000 rpm. The tach didn't even move until 2000 rpm. The sweet spot came in about 4,500 to 4,800 rpm and it stayed to north of 7000. I raced it for three years, never shifted under 7000. The motor was bone stock except for playing with the jets on the Webers.
But apples and oranges...the Italians think differently than the Germans.
Old Feb 4, 2016 | 08:10 PM
  #43
996SPECticle's Avatar
996SPECticle
Is this the op?
File Type: jpg
File Type: jpg
Old Feb 5, 2016 | 11:07 AM
  #44
rymerc's Avatar
rymerc
Totally different. Direct injection engines have carbon buildup largely due to there being no fuel sprayed over the intake ports and valves to keep them carbon free. M96 motor is still port fuel injected.
In experience, most modern automotive motors will suffer a major mechanical failure from abuse or flaw/defect before actually wearing out. Assuming the rest of the car/chassis lasts that long
Old Feb 5, 2016 | 01:05 PM
  #45
996SPECticle
Help for the tarded plz.
If there is no fuel passing through the intake ports or over the back of the intake valves and the gas charge is injected on the comp stroke with intake valve closed then burned then expelled then on the next intake stroke it has a vacuum pulling in and down more clean air, how is carbon getting there?
