Clutch Going ?
Clutch Going ?
How can you tell if the clutch is starting to go ? Just turned 77K on my 99 and I haven't had any issues, but lately it seems like it's less stiff or requires less effort than in the past.
From what I have read, the clutch pedal gets stiffer to depress when the clutch needs to be replaced. Not sure is that is true as I have never had a clutch go on me that needed to be replaced. I would imagine that the clutch bites at a much higher level when it needs to be changed. I suggest you get the car in a high gear and listen to the engine revs on depressing the gas pedal. If the revs go any higher but the car does not go faster then the clutch is slipping. I have the same year car with 78000 on the clock. Not sure if it has the original clutch but would think so as I got the car with 45000 on the clock. When was the last time the clutch fluid was changed? A bit of a pain in the **** to do but I did mine a couple of thousand miles ago. Not for any particular reason only preventative maintenance. That may help the situation.
When the clutch in my FD went, it happened very quickly. I first noticed it when under load in higher gears (accelerating on the highway in 5th). It went downhill very fast from there and was un-driveable shortly after. I'm not sure if this is normal, but its the only time I've had a clutch wear out.
Perfect, thank you for the response. It's going in for an oil change shortly anyway, and they usually come back with a "list" of items to consider fixing/replacing, so I'm sure they'll let me know.
O_Sr
In my case, the clutch started to feel "softer" on the return (release). One day it just became really soft, and it would slip under sudden acceleration.
Upon removal, it was worn out, and some of the springs (fingers) had broken in the pressure plate.
My clutch started slipping at ~55K miles and progressed rapidly (6-8 weeks, maybe) from an occasional slip to consistently slipping in 4th, 5th, 6th gears at highway speeds.
I have a 99, had the original clutch, and it made to just under a 100k miles. Like others said, my pedal suddenly became soft, which I thought might be a slave or master cylinder. But, after a hundred miles or so, began to slip. Clutch was down to almost rivets and the pressure plate had bent fingers.
When I first got the car, I had the G-box detent put in, and Swepco fluid.
Rocky Mountain High
TC
