New Stage 1 Clutch 2002 996 C2
New here, My once Porsche, is there any benefit to using a stage one clutch versus a factory clutch for my 2002 Carrera C2 3.6 L with 39k miles on it?
When I put the new cultch in, I will also replace RMS, IMS and put a short shaft in also.
I will not be using it on the track but
I do like to drive it hard.
Captain Obvious
Super User
Super User
You need to split the case if you are replacing the intermediate shaft. From what you wrote, looks like you are only replacing the bearing. I think you are using the wrong lingo here.
@OPNS I am about to do the same thing. I always put OEM stock clutch back in. Why, because I know it and like it. Until I try another setup on a 996, and like it, I am sticking with original Porsche Parts. That said, I drive mine daily about 20k annually and average 2 track weekends a year.
My 2004 has about the same milage as yours .
The car was starting to show signs of an rms leak .
So I replaced the rms , installed the same L&n bearing , and since the labour is the same and the part not that expensive replaced the clutch disk too , even if the old clutch is within limits .
It only makes sence if you've already dropped the tranny to change the clutch while you are in there .
My flywheel was fine but swapped it out for a gt3rs single mass one at the same time .
I was going to install an aasco flywheel but my Indy convinced me the other one was the way to go. And he gave it to me at cost.
Still got the aasco one new in the box if anyone is interested.
Fwiw , I went with the sport clutch , but an oem one would have been fine .
Curious...what was your indy's reasoning to opt for the GT3RS flywheel as opposed to the AASCO one? Reliability? Daily driveability?
Former Vendor
-Jason
Just wondering, and too lazy to google it at the moment.
