Windows Fogging
By turning off the A/C but letting the cabin vent fan run this dries the evaporator and as the moisture leaves that and then hits the cold air passages and condenses it will dry these out. The downside is in some weather conditions the inside glass surfaces can begin to fog up. More than once I've had to turn on the A/C to clear the fog then turn off the A/C to dry the system.
The "cabin vent fan" blowing HEATED airflow will ALWAYS clear the interior surface of the windshield of misting... whereas, A/C, only maybe
But... Ask yourself.. What happens once the A/C is shut down, manually or automatically (OAT declines below 35dF) with the condenser CLOGGED with condensate.
Best not to use A/C except for summertime cooling needs. HEAT will always clear the windshield of condensate.
A/C dehumidifying capability depends on dewpoint and OAT.
As OAT declines below ~45dF A/C dehumidifying capability declines, non-existent below 32dF.
The A/C system has a temperature sensor -- probably uses the outside air temperature sensor -- and if the outside air temperature gets too low the A/C compressor is turned off to avoid the evaporator getting too cold to the point the water that has condensed on it freezes and blocking air flow through the thing.
Does anyone know how many drain holes there are ? I think I found 2 of them near the front of the hood, but it's tough to really see much. How would you make sure they are clear ? Running some water thru them and seeing if it drains ?
You have to remove the battery cover -- you can leave the battery alone -- and the cover on each side of the battery. This exposes the 2 outliers and with a good flashlight you should see the 3rd one.
The manual calls for these to be "cleaned" the drains at any rate with compressed air. I never had used compressed air. I remove by hand all the trash then take a pitcher of water and gently pour into the water catch basin and ensure the water drains right out. If it doesn't -- and so far with my cars is always has -- one might be able to take a suitable diameter and length of a rubber hose and gently run it down the drain hole to act as a gentle (there's that word again) drain rooter.
I stress gentleness as you do not want to damage the water catch basins or the drain hose nor do you want to knock the hoses loose from the drain basins.
Yes, I'm well aware the A/C dehumidifies the air. What I was referring to is the the A/C evaporator gets wet as it is very cold when the A/C compressor is running and the moisture in the incoming air condenses on it. If one shuts off the A/C without running the fan the evaporator stays wet and can develop an offensive odor. And if one gets back in the car even the next day -- which has been my experience -- upon engine start and the cabin fan begins to blow the inside glass surfaces can develop a fog faster than one can say scat.
Yes, generally about a mile down the road. Had to pull over to the side of the road more than once and wait for the engine warm up enough.
Best to leave the A/C OFF, use HEAT!
Hmmm, while I do understand the theory behind the BS you're spewing, I don't need to "ask myself" anything
...When the windshield starts to fog up, I hit the defog button on the top left side of the climate cluster. When I do this, the defog symbol lights up as well as the little snowflake symbol (that represents the A/C in case you don't know). In addition to these two little symbols the fans also come on full blast. From this point forward it usually takes about 5 - 10 seconds to defog the windshield. If I manually shut the A/C off and leave the fans/heat on, the windsheild stays foggy. That's called annecdotal evidence (in case you didn't know) that the A/C in conjunction with the defog/defrost function, does indeed clear the windsheild. While I've never experienced foam coming from my vents, it's my hypothesis that the foam on my mixer flap is gone (my car has had 2 previous owners), and that's why my windsheild fogs so often/quickly.
I got rather tired of my windshield fogging suddenly and spontaneously and added a switch to open the A/C compressor circuit.
Once you make use of the A/C you cannot turn it off(***) absent raising the cabin Rh to the point the windshield fogs over once again, unless you heated the windshield in the interim.
***: You just drove into a cold zone and the A/C was shut down automatically... SURPRISE sudden windshield fogging.. be quick with the HEAT!
Which 996 do you have? My 2001, once the cabin has acclimated to the temperature seating, at least to within 2-3 degrees, does nothing other that route more (coolish) airflow to the windshield.
I cover the defroster vents (driver side only) with a paper towel actually, & it prevents my windshield from fogging.
Only happens in the am on way to work, when I get there, I remover said paper towels as it looks rather tacky, lol.
My solution is to manually cycle the windshield vent open and then close.
I have no idea why automotive A/C designers have chosen to CHILL the windshield on a hot day.
Or is it fogging the morning following the previous day's use of the A/C... In which case the same procedure will work.
Methinks your post be about exterior windshield fogging on a humid day.
I'll try the recycle trick the next time it happesns, but it probably won't for quite some time now.
The idea is that once you start the car you take windshield vent selection out of automatic control by switching it open and then closed. The same procedure can be used to prevent the early morning windshield interior fogging episodes.
Yes, and that's a big part of the problem. My guess is that there was a desire to widely disperse the cooling airflow such that driver/passengers are not discomforted. So, automatically, all three flow routes are open to flow once the cabin acclimates to the temperature setpoint.
