Replacement Water Pump - brand?
Oct 24, 2015 | 02:22 PM
I replaced mine with Pierburg brand two summers ago bought from 928sRus, no issues so far.
Oct 24, 2015 | 04:49 PM
There may be a more painful and significant issue than just the brand ?
Regardless of brand and the material the impeller is made of, the importance of prompt replacement is difficult to overstate.
It isn't just the ugly coolant stains or the rattle of a worn pump.
If the composite vanes deteriorate to the point hat they disintegrate ,replacing the failed w-pump is just the beginning of the repair. You need to retrieve all the broken pieces of impeller to stop them blocking coolant flow. That hunting process is worthy of it's own thread.
If the metal impeller starts cutting into the crankcase half because the bearing is worn ,you may need a new crankcase half.
There is a reason some do a PM replacement at 50k miles or less.
Oct 25, 2015 | 04:51 PM
Quote:
Originally Posted by
Warehouse33.net
Thank you, if you have any questions just let me know.
-Jason
Just placed my order today. I mentioned Reenlist. Will I qualify for 10% discount?
Oct 25, 2015 | 09:35 PM
Barn996
Did you enter the coupon code RENNLIST at checkout?
-Jason
Oct 26, 2015 | 01:50 AM
Order new bolts as well
Still cant figure out how I torqued the head off of one at 7 ftlbs when I replaced my WP a few weeks ago
Oct 26, 2015 | 01:57 AM
JayG
Um, what torque wrench did you use?
Oct 26, 2015 | 08:17 AM
Warehouse33.net
-Jason
I mentioned Reenlist, hope I did it right.
Oct 26, 2015 | 08:18 AM
JayG
New bolts were ordered.
Oct 26, 2015 | 08:23 AM
Ahsai
What are the proper torque settings?
Oct 26, 2015 | 12:01 PM
Ahsai
the same 1/4" one I used on the other bolts
Barn996
7 ftlbs
Oct 26, 2015 | 12:32 PM
1/4" should be inlb so that should be good. No ideas then.
JayG
Oct 26, 2015 | 01:22 PM
Ahsai
The only thing I can come up with is general corrosion on the bolt from 72K miles weakened the bolt. But hell, its a 10.9 high grade bolt!
I ended up replacing all the bolts for cap heads and washers. It also makes it a lot easier to get to the hard to reach bolt!
Oct 27, 2015 | 02:35 PM
JayG
Or you don't know your strength!
-Jason
