996 Forum 1999-2005
Window regulators and door lock mod
Old Oct 9, 2015 | 05:59 PM
Johns Pcar's Avatar
Johns Pcar
Default Window regulators and door lock mod
Any experience with Hamburg Technic window regulators? My inde recommended it as a replacement. He said Uro parts are junk. Pelican only sells Porsche oem and Uro.
I also need to replace the door lock module.
Is it worth paying about $400(labor & parts) to have an inde swap out the regulator or is this an easy job i can do in my garage? My skill level is fairly good but I have never screwed around with windows.
Same with the door lock module. They want $400 for that. Easy job?
Old Oct 9, 2015 | 09:10 PM
UK2's Avatar
UK2
These are both easy jobs, taking about 2 hours each...obviously much less if they are in the same door . Most of the time is spent removing the door card and the inner vapour barrier. Search on here and Pelican for the detailed instructions.
Good luck.
