996 Forum 1999-2005
Check out my sparkplug... (p1128 1130 related)
Old 10-12-2015, 09:27 PM
Ahsai
Ahsai's Avatar
If idle is 800-900, it's possible your MAF reading of 1lb/min is OK. The Porsche spec I gave requires @680 rpm.
Imre has a good point on that purge valve leaking as that will definitely create an internal air leak.
Old 10-12-2015, 09:57 PM
Youri Ko
Youri Ko's Avatar
Update :
just checked the "air vavle" per Imo insructions - mine worked perfectly
Did a voltage probing on the MAF with ingition ON = 1.1V and with car running = 1.7V at idle 900rpm.
Manual states 1.4v = my MAF is really out of whack??! Or is my idle too high at 900? manual does not specify at which idle speed 1.4V comes.
Old 10-12-2015, 10:31 PM
Ahsai
Ahsai's Avatar
Idle way too high. Spec is 680 +/-200rpm fully warmed up no load if memory serves. 900 is another indication of air leak after MAF. 1.7v at 900 sounds ok to me.
Have you checked the usual suspect - oil filler tube for air leak? Any suction if you try to remove the oil cap when engine is idling?
Old 10-12-2015, 10:36 PM
9964runner
9964runner's Avatar
If your A/C is on it will bump your idle above 680
Old 10-12-2015, 10:48 PM
theclutch
theclutch's Avatar
Originally Posted by Youri Ko
Hi there!
I'm in the procces of fighting p1128+1130 along with -20% LongTerm fuel trims and VERY loooong startup times.
Replaced the AOS yestearday but, opened the old one - membrane looked to be in perfect shape Even tough there was some oil presence in the intake ducts, so I keep hope that old AOS was somehow bad.
Have not restarted the car yet as I have to put all the hardware back. Maybe while still there, I will check my fuel pressure.
I took one of sparkplugs out , check it out :
https://lh3.googleusercontent.com/NF...8=w605-h806-no
Looks like OEM ones, the most expensive ones.
Seems ok to me, what you guys think?
No pic is showing...
Old 10-13-2015, 10:13 AM
Youri Ko
Youri Ko's Avatar
Fixed the Picture link (just figured Google Photos would show to some but not to others)
Old 10-13-2015, 10:15 AM
Youri Ko
Youri Ko's Avatar
Update :
Start it up this morning and played with Oil Cap, taking it on and off - there seem to be a good ammount of vacuum present in the crankcase, engine would start shaking, almost missfiring with the cap off.
so the AOS is brand new - where else can vacuum be pulled into the crankcase?
Old 10-13-2015, 11:42 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Check the idle air controller, they gum up too. It's bolted the the side of the throttle body. If it's stuck a bit open, the idle will go up.
Old 10-13-2015, 12:04 PM
Youri Ko
Youri Ko's Avatar
Imo - I will!
To reformulate my earlier question - is vacuum presence in the crankcase normal or not?
And If I'm to do an air leak test with some sort of smoke machine (or cigar) - should I expect smoke from oil cap or not? Pelican says there should be steady smoke from oil filler tube, which sort of answers my question already - vacuum in crankcase IS normal...or not?
Old 10-13-2015, 08:49 PM
Ahsai
Ahsai's Avatar
His is a 2001 so it should be electronic throttle -> no idle air controller.
Old 10-13-2015, 08:50 PM
Ahsai
Ahsai's Avatar
Imo - I will!
A slight vacuum (at around 4" water of suction) is normal.
Old 10-13-2015, 10:52 PM
Youri Ko
Youri Ko's Avatar
I think I found the problem...will give full update tomorow, after a test drive
Old 10-13-2015, 10:56 PM
Ahsai
Ahsai's Avatar
The suspense...
Old 10-13-2015, 10:59 PM
Youri Ko
Youri Ko's Avatar
No, seriously, found a vacuum leak by pressurizing manifold with what I had at hand.
Just don't want to shout out loud that the problem is solved unless I drive around a bit.
Old 10-13-2015, 11:48 PM
Ahsai
Ahsai's Avatar
What is that hose that you pump air into? I don't recall such air hose there.
The elbow in the last photo has an o-ring inside that can harden and leak (around the grey clip). Is it where it's leaking from?
Btw, I like how you inverted the rubber intake sleeve to seal the throttle body. Very creative
Quick Reply: Check out my sparkplug... (p1128 1130 related)
