Bluetooth and In-dash USB
While I don't do any DIY because I don't have time, which is an excuse because the real reason is I suck at it, and I am in a position to fully criticize YOUR work that I have not yet tackled, I just want to note that your Dremel cut lines are not perfectly smooth and need significant improvement.
In the mean time, I will sit here and feel good about criticizing you while I have no Bluetooth or USB in my car.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Great job dude! Nice work. I should do this.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![Embarrassment](https://rennlist.com/forums/images/smilies/redface.gif)
Yea, I did butcher it a little
Originally Posted by mannn
i have searched on this as well and settled on isimple Tranzit BLU HF
http://www.isimplesolutions.com/cont...r-any-car.html
it's around 75-80 USD on amazon... just need antenna adapter cables (two) and that's it...
everything is powered from the car except the phone. So when i need to, i just plug into the cig lighter socket for charging the phone.
The unit plugs directly into the factory radio jack and take over the frequency when it needs to stream bluetooth music. The quality is good (CD is still slightly better, but who cares when the engine sound fills the cabin anyway), sounds clear when the signal has been taken over. A lot of people in the 997 forum has installed this too.
http://www.discountcarstereo.com/BAA2223.html
It's a two cable package and you need both for this to work. One to go from antenna to the module and the other from the module to the factory radio unit
