996 Forum 1999-2005
Hood replacement (UK)
Old Sep 5, 2015 | 03:16 PM
Oil_Slickrick's Avatar
Oil_Slickrick
Default Hood replacement (UK)
Anyone had a new hood recently if so any tips, are they easy to fit (DIY) or is it better to go down the supply and fit route?
What was the quality like did you go after market or genuine and at what cost?
Any tips from outside the UK?
O_S rick
Old Sep 5, 2015 | 03:40 PM
bal's Avatar
bal
You're talking about a convertible top right? I went with a GAHH top on my 2002. I went to an auto upholstery shop that is widely used around here by the trade including the Porsche dealer. Cost me about $2k including installation and took 2 days.
Old Sep 5, 2015 | 04:51 PM
Oil_Slickrick
Thanks bal, Yes I mean the convertible top (sorry Atlantic translation), I have seen a UK company offer for about 1600$ (US) fitted. But I am not sure of the quality (its a plastic window type) hence the question. I fitted a hood years ago but it was on an old UK sports car and it was not as taught and quality as the Porsche design.
Could do with some UK recommendations
O_Sr
Old Sep 5, 2015 | 05:20 PM
Macster's Avatar
Macster
My 2002 Boxster is scheduled to get a new GAHH top installed early next week. I'm getting the same color top with the plastic window.
I was quoted around $1400 -- I think the actual cost will be a bit less than this -- and the job takes two days. One day to install -- this is what I was told -- and another to let the top sit and perhaps stretch and receive some tightening/adjustment. (The factory top needed a bit of tightening as it got a bit flappy with some use.)
Everyone I talk to has good things to say about the GAHH tops. The Porsche techs even recommended the GAHH top as the factory replacement top is super expensive. I was quoted $3229 and this with a discount. (Labor could add another $700 to that.)
In fact the techs recommended I have the new top installed at a specialist. I'm using the one they recommended. The techs told me while they have installed a number of tops, one tech estimated he installed around 10 tops over the years, this tech said it is a job one needs to do often to stay on top of this game. The specialist shop installs tops all day long and the job is routine for the techs there.
Oh, for specific UK recommendations you could check with your local Porsche dealer (OPC in UK speak) and see if it uses a specialist shop for top (and interior) work and which one.
Check with BMW, M-B dealers and see if they can recommend a specialist. Or check out ads in the back of GT Purely Porsche, 911 & Porsche World for top specialists in your area.
You can also check a UK forum for specific recommendations probably from Porsche owners in your area. Piston Heads is a UK forum with a Porsche section that's pretty good.
Old Sep 5, 2015 | 06:22 PM
Oil_Slickrick
Okay thanks for all that info
Old Sep 5, 2015 | 08:01 PM
fpb111's Avatar
fpb111
You can also go to forums. Scroll down to Rennlist UK and see if anyone knows a good specialist.
Old Sep 5, 2015 | 09:37 PM
bal's Avatar
bal
I can connect you with a mate of mine in The Independent Porsche Enthusiasts Club (TIPEC) in the UK if it is helpful. He's a 944 guy but has friends with 996s. Incidentally, you can replace the plastic window in a 996.1 with a glass one but the glass one will be narrower so that it can be accommodated by the mechanism.
Old Sep 6, 2015 | 01:32 PM
Macster's Avatar
Macster
Oh, that's a good idea. I forget there are regional forums here too.
Old Sep 6, 2015 | 02:38 PM
Oil_Slickrick
Yes thanks all for the advice
