PSM Control Module fried. Replacement options?
I've currently got PSM woes. The dreaded 'PSM Failure. Drive to Workshop" message. My indy has had the car for a week now and had traced it to a bad PSM/SBS pre-charge pump.
He replaced that and found the control module is throwing + voltage to the pump ground which probably fired the original pump. I'd love to be able to replace it with a used module but the Indy states it's coded to the car. Can anyone confirm this before I send my fried unit out for a $700 rebuilt rather than using a $80 replacement part from a dismantler? Thanks much. |
Originally Posted by Spinout
(Post 12518524)
