996 Forum 1999-2005
Suspension upgrade time
Old Jul 13, 2015 | 11:01 PM
996_North's Avatar
996_North
Originally Posted by crashclint
Did either of you have to change out anything else to get the camber correct?
I had springs, shocks and sways installed. Alignment done. Nothing needed to get the camber.
Old Jul 14, 2015 | 12:58 AM
mcbit's Avatar
mcbit
Will the car align to Porsche spec with the lowered springs with out having to buy adjustable rear links or steering tow links?
I went with PSS9/PSS10, front is OK but I currently cant get the rear camber less than -2 05'
Old Jul 15, 2015 | 10:37 AM
csubtil's Avatar
csubtil
Default Suspension upgrade time
Hi,
I have a 04 C4S Cab with 78k miles.
Last week I upgraded the suspension for Bilstein B8 + H&R lowering springs (red - lower 1 inch).
Replaced every bush possible with powerflex bushes. Also did the motor mounts (oem).
Had a hard time to align the car.
The tech used the C4S X73/74 (-20mm) (non US) reference values in the Hunter alignment machine software.
Each time he played with toe, he would mess with camber and vice-versa.
To get the 0º toe front, camber was -1º.
To get the 0º10 toe rear, camber was -2º
So ended up with plus half a degree of negative camber front + back to have the remaining parameters right.
So I do think it's needed to have adjustable toe links at the rear at least.
Did a 500 mile trip in the twisties and the ride is fantastic in terms of handling. It will wear the inside of the tires faster but I am not worried, it's not a DD, just does 3.000 miles a year...
CS.
Old Jul 15, 2015 | 04:24 PM
PelicanParts.com's Avatar
PelicanParts.com
Basic Sponsor
@narkose - If you do upgrade, I really do love KW suspension. In extensive driving tests their engineers have set the dampers for the best balance between sporty driving, comfort and safety. For the price of the V3's though, I might suggestion Ohlins here. H&R street coils are another viable option as well. If you're not looking really for a track application coil, I'd stick to KW or maybe the H&R coils.
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old Jul 15, 2015 | 05:32 PM
crashclint's Avatar
crashclint
I noticed on the Pelican Parts the H&R springs for the Coupe C2 are different then the Cab, curious as to the difference. I would have thought the cars would use the same springs.
2002 Cabriolet - HR-29513-2
2002 Coupe - HR-29513
Old Jul 15, 2015 | 06:21 PM
thewheelman's Avatar
thewheelman
Most likely due to weight, as the cab is heavier.
I think the rear shock mounting is a little different too.
Old Jul 15, 2015 | 06:35 PM
PelicanParts.com
Basic Sponsor
Yes, they are different due to, I believe, weight difference between the Cabrio and Coupe.
Old Jul 16, 2015 | 09:18 AM
crashclint's Avatar
crashclint
I am guessing the end result is the ride will be similarly stiff? My cab is definitely softer than I like. I am thinking this may be a winter project though I would prefer only a 1" drop instead of the 1.25" as the adjustable toe parts are outrageous in price for what you are getting.
Old Jul 18, 2015 | 02:05 PM
brannonspillars's Avatar
brannonspillars
With ROW M030 factory sport suspension, euro spec, I have had no issues getting it aligned to factory specs. I'm thinking about getting a slightly more aggressive alignment next.
Old Jul 19, 2015 | 03:20 AM
white out's Avatar
white out
If you don't frequently track the car, get some ksport coilovers.
