left headlight power issues?
Ok, I thought I was being thorough but I wasn't paying attention to when I had the key turned on or not when I was testing initially....
After trying the X 1/1 connector I realized I do have power where it should be.
As it turns out I have one bad bulb and most likely the bad connection at the headlight assembly socket.
Many thanks for the help to all of you!
Your assistance helped me save a couple hundred dollars.
