996 Forum 1999-2005
996.2 oem tire specs?
Old 05-05-2015, 02:19 PM
Alansglide
Alansglide's Avatar
That's the correct size for those Carrera 2 wheels. I have the same wheels on my car.
Alan
Old 05-05-2015, 02:22 PM
Thumbie
Thumbie's Avatar
After doing some research and listening to Dennis ( he is smarter than I) I was WRONG!
You currently have correct sizing for your car.
Old 05-05-2015, 02:23 PM
mcbit
mcbit's Avatar
You need a higher aspect ratio at the front to give approximately the same overall tyre diameter due to difference in tyre widths.
Old 05-05-2015, 02:32 PM
911661's Avatar
Ah makes sense thanks
Old 05-05-2015, 02:33 PM
911661's Avatar
Haha thanks for the Input no worries!
911661's Avatar
Alan
How much do you pay for tires on average.
Old 05-05-2015, 02:35 PM
911661's Avatar
Originally Posted by Dennis C
Yup. That's the correct sizing recommended by Porsche. You can verify it on the TSBs from Porsche at the site I mentioned above.
Thank you! Did the 996.2 come with a sticker that tells you the tire size? My 99 996 had one under the hood and this one doesn't
Old 05-05-2015, 02:43 PM
silotwo
silotwo's Avatar
The sticker is on the inside of the fuel filler lid. Gives sizes and inflation specs for both 17" and 18". I think I paid around $1200+ for a set 18" Bridgestone N spec at tirerack.com
Old 05-05-2015, 02:51 PM
Alansglide
Alansglide's Avatar
All depends on whether you want N spec or not.(runs for cover)
Bridgestone S04 sets are about 1100.That's my next set of tires. Prices go up from there.
Alan
Old 05-05-2015, 03:05 PM
911661's Avatar
Alan
Got it appreciate the help!
911661
911661's Avatar
Cool, I never paid attention to the inside of the filler for that information thanks!
Old 05-06-2015, 10:11 AM
kgoertz
kgoertz's Avatar
Not quite. The fronts still have a significantly larger diameter (~0.4in)
225 40 18 diameter 25.1in revs 804 circumference 78.8in
285 30 18 diameter 24.7in revs 815 circumference 77.7in
I have no idea why Porsche didn't go with a slightly lower-profile tire in the front (225 35r18) in the front. Smaller diameter means that you can have a lower car with the same suspension travel. And given the choice I'd rather have a little more sidewall on the rear instead of the front given the weight distribution.
From my experience dropping from 19"s to 18"s I can say that 0.5" of suspension travel can make a significant difference.
Old 05-06-2015, 10:59 AM
mcbit
mcbit's Avatar
0.4" on diameter gives a height difference of 0.2", makes no difference to the suspension travel and allows the AWD to work on the C4.
Old 05-06-2015, 11:09 AM
kgoertz
kgoertz's Avatar
Sorry good point. I'm not sure how I missed that.
But 0.5" of suspension travel definitely makes a very noticeable difference on handling. I would still bet that 0.2" (with the same springs) would be slightly noticeable. I'll comment more on that in the future since I'm planning on dropping my car by ~1 thread in the near future.
Quick Reply: 996.2 oem tire specs?
